Version 7.2 | Published May 08, 2017 ©
Export and Import in Template Wizard
Export and import in Template Wizard is similar to export/import in Director, with some differences related to playlists:
  • To import playlists you must first specify a Media Sequencer for Template Wizard to connect to, using the ini file or the command line. If none is specified, Template Wizard will try to connect to localhost for the playlist import. See Configuration and To specify command line parameters for Template Wizard.
    Note: The Viz Engine must be On Air before Template Wizard starts, in order for the Export tool to work correctly.
    For a full description of the import and export tools, see Export and Import in Director.
