Version 7.2 | Published May 08, 2017 ©
Configuration Files
The following configuration files are installed with the Viz Pilot system.
The default files are stored in the program folder with names in the format xxx.default.xxx.
Any changes are stored to files in %PROGRAMDATA%\Vizrt\Viz Pilot x.y\Config
File
Use
components.cfg
Default Component Palette settings for Template Wizard
custom_components.cfg
Custom Component Palette settings for Template Wizard
extra_components.cfg
keyboard.kbd
Keyboard Configuration for Director
vtw_keyboard.kbd
Keyboard Configuration for Template Wizard
