System Diagrams
graphics/vizmultiplay_standard_system_mse11.png
  • Viz Multiplay relies on Viz Trio to import graphics from a Graphic Hub. Shows from Viz Trio are available in Viz Multiplay.
  • Viz Multiplay is hosted on a URL on the Media Sequencer. Any number of Viz Multiplay clients can connect to the same Media Sequencer, which provides the scheduling for playout.
  • The Viz Engine(s) are used for playout:
    • The video wall feature means that multiple DVI outputs can come from a single Viz Engine. A Viz Engine can have up to 4 GPUs, each with up to 4 DVI outputs, giving a maximum of 16 DVI outputs. See the Release Notes for hardware requirements, and note that you should check the performance of your scenes when using this configuration.
    • Standard SDI based playout (with one Viz Engine for each output).
  • Viz Multiplay can also access the media assets stored in Viz One and Media Service.
  • Viz Multiplay can access and use templates in a Pilot Data Server.
