Working with Playlists
Viz Multichannel’s main task as an application is to import schedules, and consequently create, update and execute programming playlists. A playlist is composed of primary events (programs), which in turn can contain associated secondary events (pages and actions).
Playlists can be created as a continuous playlist or as a playlist per broadcast day. When creating a continuous playlist you cannot add playlists per broadcast day, and conversely.
Each new broadcast day playlist will have a different date, regardless of the day you created it on. For example, if you create two playlists today, the first one will be dated today by default, and the following one will be dated tomorrow.
Master Control Workflow on how to activate, initialize and manually take events on air
Working with Actions as secondary event actions in a playlist
