Introduction
To allow a seamless integration with existing hardware, the solution relies on standard rack mountable PCs instead of depending on proprietary hardware. Updates and upgrades can thus easily be implemented without requiring modifications of the solution as a whole. Viz Multichannel is the number one choice, regardless of whether the application is used for just one or multiple channels.
Some of the key benefits are:
Translate network promotions and branding strategies into rules and use them to automatically create graphics playlists
Operators can use pre-defined graphics templates
Simplify sponsoring, including automatic logging and reporting, time frame accurate reports about aired content, and “As-Run” logs
Integrates with most leading automation systems using standard protocols
Full support for SD and HD formats, real-time 2D/3D graphics and DVE effects
For Viz Engines with suitable graphic / video cards 4K and IP streaming is supported
Can be used with Viz One for access to video content
Automate an almost unlimited number of channels and monitor them all from a single Viz Multichannel terminal
Automatically adapt changes in the playlist up to the very last minute
