General Requirements
There are some general requirements for any Vizrt system to run. These requirements apply when setting up a complete system with integration to other Vizrt and third party software products:
All machines should be part of the same domain and workgroup.
Users of the Vizrt machines should ideally be separated in at least two groups, administrators and designers/operators.
Most machines running desktop applications must be logged in with sufficient privileges to run Vizrt programs, while services by default do not require users to be logged in.
Vizrt servers must have static IP addresses.
Caution: Third party systems that provide Vizrt systems with files must only use Microsoft Windows operating system compatible characters as the file name.
Vizrt has license restrictions on all Viz Engine and Viz Artist instances. To have an output of Vizrt generated graphics (preview and program channels), either an USB or a parallel port dongle on the renderer machine is required.
