Configuration Interface
Viz Multichannel settings are split in two distinct categories; global and channels where channels are the various channels that have been defined by the user in Multichannel.
Global settings apply to all channels.
Channel settings define the output channels connected to your scheduling system.
Most of the configuration work is done on a per channel basis. When configuring your channel settings, ensure that you have selected the requisite channel beforehand. Most settings are set using the Settings Window.
Settings Window
