The table tdfi_connection which contains a list of fields (or newsroomtags) that corresponds to a template description. See also information given in the td_templatedescription table.
This is a relation table defining a many-to-many relationship between the td_templatedescription and fi_field tables.
Name | Type | Allow Null | Description |
tdfi_recno | integer | No | Primary key. |
tdfi_td_recno | integer | No | Foreign key referencing the corresponding template description td_recno in the td_templatedescription table. |
tdfi_fi_recno | integer | No | Foreign key referencing the corresponding field fi_recno in the fi_field table. |
tdfi_default | varchar(128) | Yes | Optional default value for fields not of type ENUMERATION. I.e for STRING and NUMBER types. |
tdfi_em_recno | integer | Yes | Optional foreign key for the default value for ENUMERATION field types. Reference to a enumeration value em_recno in the em_enumerationmember table. |
