Gateway Administrator Guide
Version 5.4 | Published March 22, 2022 ©
Active Connections
images/download/attachments/58349635/image2017-10-24_15-25-27.png
There are primarily three kinds of connections:
Connections from an NCS to Gateway
These are connections that are established by the NCS as a connection to Gateway.
Characteristics of this connection type:
  • Only one active connection per type can be made per NCS. Connection types are identified as NCS-RO-server and NCS-MOS-server in the Active Connections window.
  • Most NCSs do not have a permanent or fixed connection to Gateway. Therefore, the connection information is only visible when the NCS sends messages to Gateway, for example when a running order is activated or updated.
Connection from a Control Station to Gateway
These are connections to Vizrt’s content control applications.
  • Only one active connection per Media Sequencer is connected to a control station. Connection types are identified as MSE-client.
  • The Host IP is the property of the Media Sequencer that the control station is using.
Connection from Gateway to an NCS
These are connections that are established by Gateway as a connection to an NCS.
  • Connection types are identified as NCS-RO-client and NCS-MOS-client.
This tab contains eight columns that are defined as follows:
  • Name: Shows the name of the entity that holds the connection.
  • Type: Type of connection. For details, see the type definitions above.
  • Port: Port used for an active TCP connection.
  • Remote IP: IP address identifying the remote system.
  • Last incoming msg: Type information for the last incoming message.
  • Last incoming time: Timestamp for the last incoming message.
  • Last outgoing msg: Type information for the last outgoing message.
  • Last outgoing time: Timestamp for the last outgoing message.
