Introduction
This guide will guide you through the setup and installation of Viz Engine. It will also explain settings available through its configuration user interface.
The term Viz is used for the programs installed and run on the computer. This is used as a general reference for all modes of the program:
Viz Engine
Viz Config
What mode of program that can run is determined from the hardware dongle that is attached to the actual machine (the different modes and the hardware dongle are detailed in this User Guide).
This Section contains information on the following topics:
