You can select how exports are created.
LST Settings
  • Export schedule after Import/Update: When checked, the schedule export process will be performed after a schedule import and/or schedule update.
  • Merge elements added by Rules with source Schedule: When checked, schedule export will be a merge export, based on the source Schedule and include elements added by rules. If unchecked, it will be an export, all elements will be included in the schedule file.
  • Schedule Export Folder: The path where a schedule file is exported to during the schedule export process.
See also:
