Edit channel configuration.
Channel Name can't be changed
New machine address must exist in channel configuration
Syntax
PUT /config/channels/{channelName}
Request
PUT /config/channels/Test HTTP/
1.1
Content-Type: application/vizrt.promoserver+xml; type=channel
<promoserver:channel xmlns:promoserver=
"http://www.vizrt.com/promoserver"
<promoserver:name>Test</promoserver:name>
<promoserver:machineAddressInUse>localhost</promoserver:machineAddressInUse>
</promoserver:channel>
Response - Machine address used for channel updated
HTTP/
1.1
200
OK
Content-Type: application/vizrt.promoserver+xml; type=channel<?xml version=
"1.0"
encoding=
"utf-8"
<promoserver:refLink rel=
"self"
type=
"application/vizrt.promoserver+xml; type=channel"
href=
"http://localhost:9980/config/channels/Test"
"edit"
type=
href=
"machineaddresses"
type=
"application/vizrt.promoserver+xml; type=machineAddressesList"
href=
"http://localhost:9980/config/channels/Test/machineaddresses"
Error Response - Machine address does not exists
HTTP/
1.1
400
Bad Request
Content-Type: application/xml; charset=utf-
8
<string xmlns=
"http://schemas.microsoft.com/2003/10/Serialization/"
>Machine address localhost is not configured
for
channel</string>
Error Response - Channel not found
HTTP/
1.1
404
Not Found
8
<string xmlns=
>Element Test could not be found</string>
Error Response - Channel name can not be updated
HTTP/
1.1
400
Bad Request
8
<string xmlns=
>Input content can
't be used to update channel: Channel Name can'
t be changed</string>
