Add a playlist to a channel. For normal installations a single continuous playlist is the recommended approach.
Name can only be "continuous" or in the date format "yyyy_MM_dd".
Broadcast date must match the name, for continuous playlist it can only be "continuous", for a playlist in date format, the broadcast date must match the playlist date with format "yyyy-MM-dd".
Description is automatically set if left empty. For continuous playlist is set to "Continuous Playlist" and for playlist in date format is set to "Playlist for yyyy-MM-dd" by default.
If any values are set for loaded, available and update, the payload will be accepted but the values will be ignored as they can't be set.
Attempting to add a playlist that already exists will return a 'HTTP 409 Can't add playlist 'NNN', it already exists‘.
Syntax
POST /api/channels/[channel]/playlists
Continuous playlist
Request - Continuous Playlist
POST /api/channels/test/playlists HTTP/1.1
Content-Type: application/vizrt.integrationshubv2+xml; type=playlist
inthub
:playlist
xmlns:xsi
"http://www.w3.org/2001/XMLSchema-instance"
xmlns:inthub
"http://www.vizrt.com/integrationshub"
inthub
:name>continuous</
inthub
:name>
inthub
:description>Continuous Playlist</
inthub
:description>
inthub
:broadcastDate>continuous</
inthub
:broadcastDate>
inthub
:playlist>
Response
HTTP/1.1 201 Created
inthub
:playlist
xmlns:xsi
xmlns:inthub
inthub
:name>continuous</
inthub
:name>
inthub
:refLink
rel
"self"
type
"application/vizrt.integrationshubv2+xml; type=playlist"
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous"
inthub
:refLink
rel
"edit"
type
href
inthub
:refLink
rel
"primaryevents"
type
"application/vizrt.integrationshubv2+xml; type=list"
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents"
inthub
:refLink
rel
"state"
type
"application/vizrt.integrationshubv2+xml; type=playliststate"
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/state"
inthub
:refLink
rel
"refresh"
href
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/refresh"
inthub
inthub
:description>
inthub
inthub
:broadcastDate>
inthub
:loaded />
inthub
:available />
inthub
:updated />
inthub
:playlist>
Playlist in date format
If events should be split by date or playlist for other usage is required, see the following example:
Request - Date Playlist
inthub
:playlist
xmlns:xsi
xmlns:inthub
inthub
:name>2019_12_01</
inthub
:name>
inthub
:description>Playlist for 2019-12-01</
inthub
:description>
inthub
:broadcastDate>2019-12-01</
inthub
:broadcastDate>
inthub
:playlist>
Response
inthub
:playlist
xmlns:xsi
xmlns:inthub
inthub
:name>2019_12_01</
inthub
:name>
inthub
:refLink
rel
"self"
type
href
"http://127.0.0.1:9991/api/channels/test/playlists/2019_12_01"
inthub
:refLink
rel
"edit"
type
href
inthub
:refLink
rel
"primaryevents"
type
href
"http://127.0.0.1:9991/api/channels/test/playlists/2019_12_01/primaryevents"
inthub
:refLink
rel
"state"
type
href
"http://127.0.0.1:9991/api/channels/test/playlists/2019_12_01/state"
inthub
:refLink
rel
"refresh"
href
"http://127.0.0.1:9991/api/channels/test/playlists/2019_12_01/refresh"
inthub
inthub
:description>
inthub
inthub
:broadcastDate>
inthub
:loaded />
inthub
:available />
inthub
:updated />
inthub
:playlist>
Note: The full contract can be used for POST, fields that are read only will be ignored.
