Once you have finished all scheduling tasks, you should manually regenerate the channels file before proceeding to monitor your playlists in MCR mode.
To regenerate the channels.ini file
From the main menu select the Tools option.
From the Tools menu click Generate Channels File. You are prompted to allow Viz Channel Branding Client to overwrite the existing file.
Click Yes.
The channels file is normally located in C:\ProgramData\Vizrt\Viz Channel Branding\ and is named channels.ini. It is a normal text file and can be manually edited.
