Some settings are configured directly in Viz Channel Branding Client's configuration files, rather than through the Configuration menus. The config file VizChannelBrandingClient.config, located in the %ProgramData% folder under \Vizrt\Viz Channel Branding\Client\
<?xml version=
"1.0"
encoding=
"utf-8"
<configuration>
<appSettings>
<add key=
"FileLogLevel"
value=
"100"
<add key=
"WindowState"
value=
"Maximized"
<add key=
"WindowWidth"
value=
"1440"
<add key=
"WindowHeight"
value=
"760"
<add key=
"WindowLeft"
value=
"1926"
<add key=
"WindowTop"
value=
"11"
</appSettings>
</configuration>
