Settings
Primary event Settings
Description
Countdown to start time
Count down timer for scheduled playout "Start Time"
Format: DD:HH:MM:SS
Start time
Static time display based on playout "Start Time"
Format: Datetime based on System settings eg.
  • Nordic: YYYY-MM-DD HH:MM:SS
  • US: DD/MM/YYYY HH:MM:SS AM/PM
Secondary event Settings
Description
Format: HH:MM:SS
Offset
Static offset time based on playout secondary event "Offset"
Format: HH:MM:SS
Calculated start time
Static time display based on playout "Start Time" + Secondary event "Offset"
Notification of error messages
Description
Collapse notification
Error "pop-up" is by default collapsed and requires a button click to display details
Pop-up notification
Error "pop-up" is by default showing and displays details, can be closed by pressing the close button
Working with Settings
Changing Settings
To update settings
  1. To update settings, press the Menu button at the bottom-right.
  2. Select Settings.
Changing Layout
To Change the view layout
  2. Select Change layout.
