Viz Arc lets you import Unreal Levels from a specific project (selected and opened manually in Unreal Engine software).
Note: Please see Configuring Profiles to correctly configure Unreal Engine in Viz Arc.
First, open the Unreal Engine software and select a project. Once the project is loaded, click the Play button to switch to Play mode.
In Viz Arc, click the ADD SCENE icon on the left side of the window and select the Unreal panel.
Once selected, you need to load the scene by clicking the LOAD SCENE icon in order to retrieve details.
Double-click the root folder to show the list of elements. To create an action, drag and drop available content from the tree into the actions area.
Load an Unreal scene by right-clicking on an empty space in the actions area.
Once the relative action has been created, in edit mode, click Select Unreal Level to open the browse window.
Select the desired level and double-click it to load.
