Configure a Tracking System
To Add and Configure a Tracking System
graphics/setup_tracking_topol_new.png
  1. Click graphics/setup_plus_button.png .
  2. Type a Name for the configuration.
  3. Select which protocol to use to receive data from the tracking system:
    • FreeD (see Description of the FreeD protocol)
    • RTHead
    • XML Tracking: A special feature, a self-definable protocol for special solutions
    • Motion Analysis
    • mo-sys
    • Trackman
    • Vicon
    • Libero
    • CanonLens (Zoom and Focus driver for canon lenses)
    • Spidercam
    • Flair
    • Thoma
    • Stype A5
    • Stype HF
    Note: If changing the protocol of an already configured tracking system, the default configuration parameters for the new protocol will be read by the system.
  4. Select a connection type. Depending on the tracking system select the connection type:
    • Serial: If serial is selected, also select a Comport (in the Comport box, all available comports are shown). If the default baud rate is not used, enter the correct one in the baudrate field
    • TCP/IP: Type in the Host IP to use (possible port as well)
    • UDP: Type in a Port number to use
  5. Right-click on the Tracking Systems box and select Connect (connect to the tracking system).
    graphics/setup_track_connect.png
    The Tracking Hub now connects to the selected Tracking System. Observe the colors on the bottom of the symbol:
    • Green: Connection is done and data receiving in time
    • Orange: If the color becomes orange, after a few seconds, connection is done and data receiving, but not in time
    • Red: If the color becomes red, possible connection failure or data is not received.
  6. Go to Configure a Rig.
