The Feed-backed drop-down option works exactly like the Enable feed browser option, but displays the results in a drop-down instead of in the feed browser window:
Example: Link Image Field to Graphic Hub Folder
In this example we set up a link from an image field in the template to a Graphic Hub folder, and present the result in a sorted drop-down.
  • For the image field in the template, choose Feed-backed drop-down from Data entry.
  • The Feed URL should point to a Graphic Hub folder, and we added a search term parameter to display only images. The URL is part of the Graphic Hub REST API.
    To quickly build a valid URL to a folder in Graphic Hub, follow these steps:
    • Click the folder icon to browse the configured Graphic Hub:
    • The {$GH} environment variable can be used to build the base URL part. This variable resolves to the configured graphic hub on Pilot Data Server (for example, http://gh-host:19398/).
    • Alternatively, to build the URL manually, add /files/ to the base URL of Graphic Hub, and add the UUID of the folder to the URL. This value can be copied from Viz Artist when browsing in Asset view:
    • Add the ?term=IMAGE to the URL. For instance:
      {$GH}/files/BAA340C1-C71E-0949-BCF6-F7E043856030/?term=IMAGE
  • In the Select from feed item drop-down, select Entry. This certifies the complete Atom entry is put into the field, making it playable for Viz Engine.
  • Click Sort by title to make the entries sorted.
  • The result should be a sorted drop-down with the images in the Graphic Hub folder.
