The viz_sealevel plug-in allows Viz Engine to provide GPIO data coming from SeaLevel Devices for plug-ins and scripts.
Both SeaLevel PCI and ethernet Devices are supported. The GPIO data is provided in via SHM key/values and via message passing.
SHM Interface
Each GPIO pin is mapped to a SHM key.
Format
The pins are mapped with following format:
Inputs:
Sealevel::<device-id>::I<pin-id>::<0 or 1>
Outputs:
Sealevel::<device-id>::O<pin-id>::<0 or 1>
SMM Values in Viz Engine REST Interface
Inputs
These SHM values are only for reading and are updated when a input pin changes. By registering to SHM changes this can then be used to perform tasks in scripting or plug-ins.
Outputs
These values are meant to set from inside scripts or plug-ins (for example to switch lights on and off).
Message Interface
The Viz Engine plug-in API supports communication via message passing which is similar to a REST API. Messages can be send via Request(location, message)
in Viz Script.
List Devices
Response:
"id"
"1"
"name"
"410io_"
"status"
"connected"
"status-description"
"Connected"
Get Device Info
Response:
"id"
"1"
"name"
"410io_"
"status"
"connected"
"Connected"
"pins"
"id"
"0"
"is-input"
true
"value"
0
"id"
"1"
"is-input"
true
"value"
0
"id"
"2"
"is-input"
true
"value"
0
"id"
"3"
"is-input"
true
"value"
0
Register for Pin Changes
Response:
"error"
false
If then a pin changes the script or plug-in would receive such a response:
Response:
"device"
1
"pin"
1
"value"
true
Get All Pin Data for a Given Device
Response:
"id"
"0"
"is-input"
true
"value"
0
"id"
"1"
"is-input"
true
"value"
0
"id"
"2"
"is-input"
true
"value"
0
Get Pin Data for a Given Device and Pin
Response:
"id"
"0"
"is-input"
true
"value"
0
Set Pin Data for a Given Device and Pin
Message:
"value"
1
Response:
"id"
"0"
"is-input"
true
"value"
1
Configuration
To Configure this plugin create a file called {VizEngine-Config-dir}/extensions/Sealevel.json. This file is used for every running instance of Viz Engine. To have a specific config for a running instance you can create config files like {VizEngine-Config-dir}/extensions/Sealevel-{Instance-Number}.json.
Supported config parameters:
auto-reconnect: Automatically reconnect to device.
reconnect-interval: Interval for reconnecting.
discover-ethernet-devices: Automatically detect SeaLevel network devices.
ethernet-devices: Array of SeaMax devices connected via Ethernet.
address: IP address.
name: Assocciated name for this Card.
seaio-devices: Array of SeaIO device (PCI-Cards).
adapter: Adapter number for PCI-Card (For two installed PCI-Cards possible adapters would be 0 and 1).
serial-devices: Array of SeaMax devices connected via serial interface.
port: COM port for this device.
The Sealevel.json file would then look like this:
"auto-reconnect"
true
"discover-ethernet-devices"
true
"ethernet-devices"
"port"
"COM1"
"name"
"serial_card_0"
"reconnect-interval"
60000
"seaio-devices"
"adapter"
0
"name"
"pci_card_0"
"serial-devices"
"port"
"COM1"
"name"
"serial_card_0"
Sample Scripts
List Devices
sub getDevices()
Request(
"/Extensions/Sealevel/devices"
end sub
sub onDevices(devices as Json)
if
devices.Size ==
0
Then
exit sub
end
if
dim devCount as Integer = devices.Size -
1
for
i =
0
to devCount
dim deviceObj as Json = devices.At(i)
Println(deviceObj.Dump())
Next
end sub
sub OnResponse(location as string, message as string)
if
location ==
Then
dim j as Json
j.Load(message)
onDevices(j)
end
if
end sub
getDevices()
Get Pin Values
sub getPinValue(devId as String, pinId as String)
Request(
"/Extensions/Sealevel/devices/"
& devId &
"/pins/"
& pinId,
end sub
dim j as Json
j.Load(message)
onPinValue(j.GetString(
"id"
), j.GetInteger(
"value"
end sub
sub onPinValue(pinId as String, value as Integer)
Println(
"Pin "
& pinId &
" value = "
& value)
end sub
' Inputs
for
i =
0
to
15
getPinValue(
"0"
& i)
next
' Outputs
for
i =
16
to
31
getPinValue(
"0"
& i)
next
Set Output Pins
Request(
& devId &
"/pins/"
& pinId,
end sub
sub setPinValue(devId as String, pinId as String, value as Integer)
dim payload as String =
"{\"value\": "
& value &
Request(
& devId &
"/pins/"
& pinId, payload)
end sub
dim j as Json
j.Load(message)
"id"
), j.GetInteger(
"value"
end sub
Println(
"Pin "
& pinId &
" value = "
& value)
end sub
setPinValue(
"0"
"16"
1
setPinValue(
"0"
"18"
1
' Outputs
for
i =
16
to
31
getPinValue(
"0"
& i)
next
Listen for Pin Changes
if
location.StartsWith(
) and location.EndsWith(
"change"
) Then
dim j as Json
j.load(message)
onPinChanged(j.GetInteger(
"pin"
), j.GetInteger(
"value"
end
if
end sub
sub onPinChanged(pinId as Integer, value as Integer)
Println(
"Pin "
& pinId &
" changed to "
& value)
end sub
Request(
"/Extensions/Sealevel/devices/0/register"
