XR Draw is a Viz Engine Shader plug-in that dynamically generates and renders an extruded mesh geometry along a path.
It can be used for 3D Telestration in an XR-Set Environment.
Note: This plug-in is located in: Plugins -> Shader -> Material
XR Draw Properties
  • Point X: Current input position in X.
  • Point Y: Current input position in Y.
  • Point Z: Current input position in Z.
  • Threshold: Minimum distance between points on path.
  • Radius: Radius of the extruded base geometry.
  • Contour points: Number of contour points of the extruded base geometry.
  • Color: Sets the color used to render the geometry.
  • Texture: Determines texture used to render the geometry.
  • Scale U: Sets scale factor for the generated UV coordinates in U direction.
  • Scale V: Sets scale factor for the generated UV coordinates in V direction.
  • Start drawing: Starts recording points and generating the geometry along the recorded path.
  • Stop drawing: Stops recording points.
  • Clear Points: Clears all recorded points and reset the drawn geometry.
Note: The recorded points are not being saved, as the purpose of the plug-in is for live drawing.
