Callbacks
PLUGIN_EXTENSION_CONFIGURE
Signature
int PLUGIN_EXTENSION_CONFIGURE(void* pvDataPtr, const char* configStr)
Required
No
Description
Called to configure the extension plug-in. This function is called if a configuration file for this extension exists with a <configStr> parameter.
PLUGIN_EXTENSION_CONFIG_GET
Signature
const char* PLUGIN_EXTENSION_CONFIG_GET(void* pvDataPtr)
Required
No
Description
Called to get the current configuration of the extension plug-in. The return value is expected to be the content of the serialized configuration.
PLUGIN_REQUEST
Signature
void PLUGIN_REQUEST(void* pvDataPtr, int connection, const char* location, const char* msg)
Required
No
Description
Called whenever a message is received for this extension.
Note: This function is always called on the main thread.
  • connection: object-id of sender (must be used for _api__respond)
  • msg: message payload
PLUGIN_RESPONSE
Signature
void PLUGIN_RESPONSE(void* pvDataPtr, const char* location, const char* msg)
Required
No
Description
Callback for incoming responses [Messages].
After calling _api__request this function is called with the response message.
Functions
_api__get_plugin_objectid
Signature
int _api__get_plugin_objectid();
Description
Returns the object ID of the current plug-in. Can be used for _api__request.
_api__request
Signature
void _api__request(int iObjectID, const char* location, const char* msg)
Description
Sends a message request.
Note: Function can be called at any time and is thread-safe.
  • iObjectID: object-id of the current plug-in. Can be retrieved by calling _api__get_plugin_objectid.
  • msg: optional message payload
Example: If an extension provides a message endpoint of "/Extensions/Sample/greet".
You could make a requests with _api__request(myObjectId, "/Extensions/Sample/greet", "")
_api__respond
Signature
void _api__respond(int iObjectID, const char* location, const char* msg);
Description
Can be used to respond to a message request. If a message is received by getting PLUGIN_REQUEST called. You can respond with this function (immediately or at another time).
  • iObjectID: object-id which got passed by PLUGIN_REQUEST
  • msg: the response message body
