The P Quad plug-in creates a rectangle with different attributes.
Note: This plug-in is located in: Plugins -> Geom plug-ins -> Primitives
P Quad Properties
  • Use LOD: Enables/disables dynamic level of detail.
  • Tesselation: Sets the degree of detail.
  • Bevel: Sets the radius of rounded edges.
  • Width: Sets the width of the quad.
  • Height: Sets the height of the quad.
  • Corners: Sets the number of the corners for rounded edges.
  • Use Control Vertices: Allows the four edges of the quad to be moved individually. With the following parameters, edges can be placed in X and Y directions as desired:
    • LowerLeft X
    • LowerLeft Y
    • LowerRight X
    • LowerRight Y
    • UpperRight X
    • UpperRight Y
    • UpperLeft X
    • UpperLeft Y
  • Use Vertexcolors: Allows the color of the edges to be set when enabled. With the following parameters, individual colors can be selected:
    • UpperLeft
    • Lower Left
    • Upper Right
    • Lower Right
