The Monitor Shader plug-in simulates the appearance of a flat screen display where saturation decreases at grazing angles of view. The shown color texture blends into the diffuse color of the material.
Additionally, a reflection from the surrounding (from a cube map) is added, increasing in strength towards more acute angles of view.
Monitor Shader Properties
Saturation/Reflection/Color Gradient: Defines to which amount the material’s diffuse color is mixed into the resulting color at grazing angles.
Reflection Multiplier/Exposure: Affects the exposure of the environment map. This is especially helpful when working with HDR images.
Gamma of EnvMaps: Controls the gamma correction of the environment map. This is once again particularly helpful when working with HDR images.
Environment Map: is a cube map that describes the environmental surrounding used to calculate reflections.
Saturation_and_Reflection_Gradient: Is a technique to influence saturation and reflection appearance alike.
Reflection_Gradient: Is a technique to influence only the reflection appearance.
Monitor Shader Best Practices
Apart from the parameters in the plug-in container, it is necessary to assign a material and a texture as a color/basic texture. For this shader, a background image should be selected as the basic texture to achieve a highly realistic monitor effect. Do not forget to adjust material parameters in addition, such as ambient, diffuse, specular color and shininess, to achieve the required look for your surface.
