The Map Builder plug-in builds a scene from a map template (*.mtpl) file, and saves the map scene changes to the map template file.
Note: This plug-in is located in: Plugins -> Scene plug-ins -> Maps
Map Builder Properties
Map Template Filename: Sets the name of the scene template file or click the browse (...) button to select a file.
Rebuild Scene: Updates the scene tree with changes from the Map Builder.
Launch Wizard: Runs the Map Builder application.
Clean Scene: Cleans the scene hierarchy.
Build Scene from Scratch: Cleans the scene tree and rebuilds the scene hierarchy using the defined map template file.
