The Light Blur plug-in allows the user to configure and create a light blurred image.
Note: This plug-in is located in: Plugins -> Container plug-ins -> Texture
IMPORTANT! The light blur functionality is now a built in feature of the Viz Artist/Viz Engine core. For future use, it is recommended to use the Dynamic Texture Media Asset.
Light Blur Properties
  • Width and Height: Sets the width and height of the blurred light. Available options are 2 to 2048.
  • Format: Sets the image format. Options are:
    • RGB
    • RGBA
    • Alpha
    • Luminance
    • Luminance Alpha
  • Save: Saves the blur as an image.
  • X and Y (%): Sets the position of the blur on the X and Y axis (50% places the blur at the origin).
  • Spread (%): Sets the spread of the blur.
  • Start: Sets the start color of the blur.
  • End: Sets the end color of the blur.
