The LED Panel plug-in creates an LED panel style texture.
Note: This plug-in is located in: Plugins -> Shader -> Effects
LED Panel Properties
  • Pixel Size: Determines the size of pixels in the LED board.
  • Billboard Size X: Determines the width of the LED board (for example, using a Pixel Size of 1 and a Billboard Size of 10 shows ten LEDs).
  • Billboard Size Y: Determines the height of the LED board.
  • Tolerance: Threshold that defines which pixels belong to an LED.
  • Pixel Radius: Sets the maximum size/radius of the LED.
  • Luminance Steps: Determines number of discrete luminance steps the LED panel is able to show.
  • Luminance Boost: Determines factor to increase luminance.
  • Color Boost: Enhances the RGB values of the image.
  • Noise: Defines texture where LEDs are already burnt out or damaged (white is interpreted as functional, black is treated as damaged).
  • Wrap: Sets whether to use texture repeat or clamping mode.
  • Burnt Out Percent: Determines the percentage of pixels that appear to be broken or burnt out.
  • Background Color: Determines the background color of the LED board.
