The Drop Shadow plug-in generates 2D shadow of a texture.
Note: This plug-in is located in: Plugins -> Shader -> Texture
Drop Shadow Properties
Distance: Sets the distance of the shadow.
Direction: Sets the direction of the shadow in degrees.
Threshold: Sets the shadow threshold.
Soft Shadow: Enables the Soft Distance parameter for applying a soft shadow.
Soft Distance: Sets the distance of the soft shadow.
Color: Sets the color of the shadow.
