The Control Condition plug-in triggers actions based on the input given in a tab-field with the same field identifier.
Control Condition Properties
Input Value: Shows the current input value of Control Condition.
Format: Sets the format for the input value that it should conditionally trigger on.
Condition: Sets the type of condition if Format is set to number.
Arguments: Sets the arguments for the conditional operation.
Action Type / Action: Sets the action that is to be performed when the condition is met. It can be a control object command like
“ON 2 SET mytext”
or a Viz Engine command prefixed by a zero and a space.Use Else Commands: Triggers an else action when the input data falls within the conditions when enabled.
Else Action: Sets the else action that is triggered when the input data does not fall within the conditions.
Example Actions
Actions can be Control Object commands in the form like this: “ON 2 SET Mike Johnson”
or commands like: 0 RENDERER*STAGE START
Note: Viz Engine commands must be prefixed with a zero followed by a space. This is to enable the plug-in to recognize that the command should be interpreted as a Viz Engine command.
