The Control Clip plug-in binds control of an AVI clip played by MoViz or SoftClip to a Control Object. With Control Clip, the clips may be changed within the control application.
The MoViz plug-in enables the user to play media files or media streams inside Viz Engine. MoViz uses the Microsoft DirectShow Filtergraph framework to render the media. It is possible to play files (for example, MPEG and QuickTime) or streams from a server. For the latter to work, the system must be appropriately equipped.
SoftClip is a Viz Artist/Viz Engine plug-in that can show AVI clips, either projected on a texture, or rendered directly.
Control Clip Properties
This plug-in does not have any properties or parameters except those that are common to all plug-ins.
