The Cog Wheel plug-in creates a cog wheel.
It has a range of properties to adjust the look of the cog wheel.
To avoid decreasing the system performance, set the tessellation to a lower value since it does not make much difference in quality.
Cog Wheel Properties
  • Use LOD: Enables/disables dynamic level of detail.
  • Tesselation: Sets the level of detail.
  • Corners: Sets the number of corners the cogwheel is to be constructed of. The cog wheel gets one tooth for each corner, so the number of teeth changes correspondingly.
  • Height: Sets the height or width of the cog wheel.
  • Tooth height: Sets the height of the cog wheel teeth.
  • Diameter: Sets the diameter of the cog wheel.
  • Hole: Creates and sets the size of a hole in the cog wheel.
  • Bevel: Sets the degree of bevel at the cog wheel.
  • Inner Bevel: Enables or disables bevel in the cog wheel hole.
  • Show Top: Enables or disables visualization of the top.
  • Show Bottom: Enables or disables visualization of bottom.
  • Center: Allows you to select where the geometrical center should be placed on the cog wheel: Either CenterBottom or Top.
To Create a Cogwheel
  1. Add the Cog Wheel plug-in to a container.
  2. Add a material to the same container.
  3. Set Hole parameter to 50.0.
  4. Set the transformation parameters for the container to: Rotation X: 90.0 , Y: 45.0 and Z: -45.0 .
