The 2D Line plug-in draws a 2D line through given 2D coordinates, respective to point values.
2D Line Properties
use LOD: Enables level of detail. Range:
On - Off
. Default:On
.Enable Outline: Enables drawing of an outline. Range:
On - Off
. Default:On
.Width: Defines the width of the drawn line. Range:
0.0 - 500.0
. Default:5.0
Point values: Lists x,y pairs separated by ‘:’ character. x and y values are separated by blanks.
Example:0 0: 100 100: 200 70: 300 240: 400 280: 500 240: 600 400
.New Line: Press before values are entered (i.e. Point values), or else the line is rendered as invisible.
Clear All: Deletes all line-segments.
To Create 2D Lines
Enter the Point Values. For example,
0 0 : 200 45
entered in the Point Values field creates a line that starts at the point X1(0), Y1(0) and ends at point X2(200), Y2(45).Click the New Line button to create the line.
