When deploying Pilot Data Server behind a proxy server, it is often necessary to rewrite requests, to ensure the application interprets and responds to client requests correctly. This process typically involves adjusting elements of the request to account for modifications introduced by the proxy, such as altered hostnames, schemes, or paths.
There are two primary methods for aligning the application's URL with the external-facing URL used by the proxy.
Using X-Forwarded Headers
The proxy server must either populate the X-Forwarded headers or the Forwarded header in order for Pilot Data Server to serve the appropriate hostname, port and protocol in its responses:
  • Forwarded
  • X-Forwarded-Host
  • X-Forwarded-Port
  • X-Forwarded-Proto
Use a proxy server with the above headers configured. If the Forwarded or X-Forwarded headers are not configured, the proxy server can be configured to pass the Host header it received from the client to Pilot Data Server.
Configure Base URL
An alternative method is to explicitly configure the application’s Base URL to match the external-facing URL provided by the proxy.
This cannot be combined with the forwarded-headers mentioned above.
Note: The Base Path cannot be combined with neither forwarded-headers nor the Base URL. The base path is only applied to the internal URL when no proxy is configured.
Redundancy and Failover
Although Pilot Data Server has been designed without built-in redundancy, it does support being used with off-the-shelf third-party HTTP load balancers. As the name suggests, a load balancer's main function is to distribute requests among multiple servers. Multiple servers provide redundancy, and most load balancers come with an option to only route requests to servers that respond, which provides failover.
Both Barracuda Load Balancer ADC and HAProxy have successfully been used in front of Pilot Data Server.
Load Balancer Quick Setup
Quickly set up a HAProxy load balancer:
Prerequisites
  • Two (or more) hosts running Pilot Data Server, connected to the same database. They have host names pds1.example and pds2.example for the purpose of these instructions. Static IP addresses may be used instead.
  • A Linux host that turns into a load balancer. It has the host name proxy.example for the purpose of these instructions. This is the host used in the installation steps below.
Installation Steps
  1. On the Linux host, install HAProxy with the command sudo apt-get install haproxy.
  2. Edit /etc/haproxy/haproxy.cfg (for example with sudo nano /etc/haproxy/haproxy.cfg) and append the following lines:
    frontend http-in
    bind :8177
    default_backend servers
    backend servers
    server server1 pds1.example:8177 check
    server server2 pds2.example:8177 check
    listen stats
    bind :80
    mode http
    stats enable
    stats uri /
  3. Restart HAProxy with the command sudo service haproxy reload.
Notes
  • After following the steps above, it should be possible to use proxy.example:8177 in place for pds1.example:8177 and pds2.example:8177. Check whether the setup works by opening http://proxy.example:8177/  in a browser. The Pilot Data Server index page should load.
  • The above configuration also provides a monitoring page at http://proxy.example/, that shows which Pilot Data Server hosts are responding. This does not tell you whether Pilot Data Server is working correctly, as hosts still respond when they cannot reach the database.
