The table below shows all of the default Protocols and Ports used with Pilot Data Server.
HTTP
Name
Default Value
Comments
Pilot Data Server
http://pds-host:8177
The port used for HTTP is configurable in the DataServerConfig.ini file on %ProgramData%\Vizrt\Pilot Data Server.
Script Runner
http://pds-host:1981
Installed with Pilot Data Server and runs on the same host machine. The port used for HTTP is configurable in the file PilotScriptRunnerHostService.exe.config in the Pilot Data Server installation folder.
Crop Service
http://pds-host:8178
Separate installer that normally runs on the same host as Pilot Data Server. The port used for HTTP is configurable in the file PilotCropServiceHost.exe.config in the Crop Service installation folder.
Graphic Hub REST
http://gh-host:19398
Graphic Hub uses the same port for HTTP and HTTPS.
Viz One
http://vizone-host:80/thirdparty
Preview Server
http://ps-host:21098
REST VOS / GH Image Extension
http://imex-host:19390/restvos/service
The image extension UI can be accessed on http://imex-host:19390/imagelibrary/index.html.
Viz Pilot Preview Port
50008
Viz Engine preview port used for snapshot previews in Viz Pilot.
Viz Arc MOS Panel
http://arc-host:9004/mos-plugin
PDS changelog notifications
stomp://pds-host:9876/?destination=/changelog&lastKnownId=-1
HTTPS
Name
Default Value
Comments
Pilot Data Server
https://pds-host:7373
The port used for HTTPS is configurable from the Pilot Data Server Launcher. The service needs to restart.
Script Runner
https://pds-host:1982
Crop Service
https://pds-host:8179
Graphic Hub REST
https://gh-host:19398
Viz One
https://vizone-host.example.com:443/thirdparty
Preview Server
https://ps-host:4443
No support for HTTPS.
50008
Viz Arc MOS panel
https://arc-host:9005/mos-plugin
