Version 3.0.1 | Published May 10, 2017 ©
Viz Pilot Database Management
This chapter covers management of Viz Pilot databases when the Graphic Hub is used as a Pilot data back end server.
Before setting up Graphic Hub as a back end database for Viz Pilot, observe the following:
The server must meet the minimum hardware requirements for Graphic Hub as Viz Pilot back end system which may vary depending on the size of the installation.
Viz Pilot requires Graphic Hub REST. The server running the GH REST service needs to meet the Graphic Hub REST Requirements.
The schema version is bound to the Graphic Hub version. Pilot schema 6 or Pilot schema 7 can be imported.
Media Sequencer 4 is required for Pilot 7.
The upgrade is performed when Graphic Hub is upgraded and started.
Make sure to have the documentation for Graphic Hub and Viz Pilot at hand before proceeding with the installation. The latest documentation is always available at www.vizrt.com.
This chapter contains information on the following topics:
Viz Pilot official documentation
